SOURCE: philips tv blinking red light
I've seen this problem before with Philips. 6X3X blink was the X-sus or Y-sus boards. In other words, the TV cannot make the picture on the screen properly, so it won't even try and will shut down.
I've also had difficulty getting these parts from Philips (even while being an authorized service center). If you have an authorized service center near you, you might want to give them a try because I don't believe they were too expensive, just hard to get.
I hope this helps you...
SOURCE: Sony Grand vega 55" will blink green for three times than red
Your problem is your thermal fuse.It is located around the bottom of the compartment that houses the lamp. You will have to remove the lamp and take the bottom back panel off. Then you will have to remove the fan. I ordered the thermal fuse so I would know what I was looking for when I started to replace it. If you take your time and are patient enough you can fix it yourself. I fixed mine and it's working great.GOOD LUCK!!!
SOURCE: No picture no sound. All three lights blinking off
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open
unit up and take a look at the power supply board.You will probably see
one or more electrolytic filter capacitors that are bulged up in the
top-not perfectly flat like the others.
The value of these
capacitors will be different, most likely they will be somewhere
around-820 to 2200uF/25 V( or /10V sometimes)
You
can replace them with same values but I would recommend the voltage
rating to be higher(like 35V for an original 25V) for reliability
purposes.
What happens is,these bulged top capacitors will cause a
low and unfiltered DC voltage=main board will malfunction(the relay
will keep clicking until the caps are holding enough charge to bring the
voltage up over a threshold point).
You can buy these capacitors
at any Fry's or Radioshack store or you can order them online at vendors
like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There
may be also some other causes for this symptom ,like a defective T con
board ,or main board,but the bulged top capacitors are the most common
cause for this issue.
If you don't know about TV repairers, take
the TV to the nearest repairman to fix the fault for you. Also, note
that TV stores a lot of current, so wait a while before opening the TV
back cover.
I hope this helps.
Good luck.
SOURCE: When TV is turned on,
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
