I recently acquired a 75" Hisense 4K UHD HDR Smart TV that just turned 2 yrs. old but stopped working 6 months ago! The tv powers on, has sound, but no picture. The red power-indicator light flashes a few times when turned on. When I put the flashlight up to the screen, there ARE images there. Best Buy's Geek Squad did an in-home diagnosis of a bad Power Board; however, I just replaced it with 1 from Shopjimmy and the exact same problem persists, so the Power Board obviously wasn't the issue (way to go, Geek Squad!). I'd surely be grateful for any suggestions anyone can offer.
The leds are wired in series
One burned out stops them all
If you can see the picture it is almost certainly the leds
Isolate the burned out strip and replace it
1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
