SOURCE: error codes of my kyocera KM 1635
c3100 is a scanner home position error, does the scanner move when turned on with lid up? if not its the motor, if it moves then it mat be a sensor (usually "U" shaped in rear left under glass, or it could be "locked" for shipping, look for a switch on left side or under scanner unit. hope this helps.
SOURCE: How to reset maintance call on kyocera km-1635?
10871087 then 251 then hash key then set it to 0 or cancel to reset the counter
SOURCE: MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
SOURCE: My Kyocera Mita KM-KM 1635 displays error call c6000
press 1087 1087 than insert 163 than press start 4 time
