SOURCE: Vertical line up and down middle of TV screen
i think this is the called picture in jail. this might be due to 1 power supply reg.poor or filter cap dry. 2 loose or dry joint nera hor. output section or capacitor in eht section.
SOURCE: v235
install the data cable driver and the pc suite which will be there in cd with the data cable ... after installing then connect ur mobile to pc ... in that pc suite there will be options to transfer from pc and to cell also just the option will be something like "Phone to pc" or "To pc" click on that and select the files to be downloaded to pc.... that s all it s done....
SOURCE: lg ke 500
Tengo el lg me 550 y necesito el driver para windows vista lo detecte, mi correo es: [email protected]
SOURCE: to change my computer languages from english to hebrew
go to start menu and then to control panel
find the icon language or regional setting
follow the prompts
SOURCE: Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
Open Desktop Background by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Desktop Background.
Click the picture or color you want for your desktop background.
If the picture you want to use is not in the list of desktop background pictures, click the Picture location down arrow to view other categories, or click Browse to search for the picture on your computer. When you find the picture you want, double-click it. It will become your desktop background and appear in the list of desktop backgrounds.
Look for pictures in other locations on your computer
Under How should the picture be positioned, choose to have the picture fit the screen, tile, or be centered on the screen, and then click OK.
If you choose to have a centered picture as your desktop background, you can also have a color background to frame your picture. Under How should the picture be positioned, click Change background color, click a color, and then click OK.
Windows 7 Starter edition comes with one desktop background, which can't be changed or customized. Please see this link for details.
http://windows.microsoft.com/en-US/windows7/Personalize-your-computer
or if on XP on the desktop right click got to properties select settings and adjust the slider
To change the desktop background
