Samsung DLP Facial Colors off after changing color wheel
I recently changed my color wheel (which was shattered into pieces). After changing the color wheel, the facial color (skin color) changes from the normal color to pinkish yellow. Also the background has the same issue with some color patterns. Not sure what the problem is. Please advise. Thank you very much.
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
I'm not sure you received the correct color wheel. Do you have anything left of the shattered color wheel to compare it to the new one? Seems if you got the correct wheel then the colors should of been the same. Color wheels spin at the same rate of 60Hz. The only reason why you would get the wrong color is that the color on the wheel is in the wrong placed at the right time. I would see if you can get a wheel the same # as your original one.
Sounds like a bad color wheel----remove lamp---the wheel faces it--look
for missing pieces or the wheel shattered---these are known for the
wheel making a loud high pitched sound or even a grinding sound if the
wheel shatters.
if wheel bad You Tube has video instructions for
replacing it---seen several people able to do this themselves in about a
hour. Google the model number to ("color wheel") to locate a
replacement on the internet.
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Ur tv have a colors wheel design in it.Tv have buzzing,squiling or loud motor noises.Have colors turn in Black&White or flashes white within pictures.All these causes and problems are the effect of the colors wheel is dying and require repacement of the colors wheel,because it is woring out and not spinning correctly on it motor axis anymore.Have no machanical experience taking things aparts and putting it back together again.Don't atempt to change the colors wheel by ur self,bacuse the colors wheel sit way back on the tv,must take out many machanicals parts before u can even come to it to change it.Hire a Tv Tech. to change the colors wheel ok best solutions and no complication taking out the old one and putting in the new colors wheel,for it to functions correctly.
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
Hi. The most common cause for this is the color wheel. Replacing it requires removal of the engine/optical block. I'm not sure of your level of expertise but if you want to give it a try go to this website: http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ It'll give you some idea of what you're up against. It is similar to what you'll have to do but I don't think your chassis is exactly the same as this one so some things will look different inside.
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
