Back to:
Tags:
Frigidaire FGF316 Gas Kitchen Range
Carbon mono detector alarming, flames high
posted by tlhanle on Nov 22, 2007
just used stove for first time, when only on a few minutes the flames are orange and really high in the oven then the carbon monoxide detector alarms , what do i do?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 22, 2007
Thanks for Trying (70)
chris72
Rank:Guru Guru
Rating: 93%, 396 votes
the oven comes from the factory set to be used on natual gas. its souds like your on LP gas. if so there should be a conversion kit with the range or instruction in the owners manual on what to do to convert it. all ranges ar diverent when it comes to converting. you need to follow the instruction in your manual
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on carbon mono detector alarming, flames high:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
Older convection element in oven burnt out. Put in new...
Ignitor is on - smells like gas, but oven won't turn on. ...
Oven lights-gets up to temp-but wont re-lite to get back...
the ignators do not stop, even when the range is off
frigidaire #modelfgf326asa serial#vf20225212 the bake...
Loading problems.
Repair Service
Find Kitchen Range Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
