I need hitachi 3390fsp str and optocuplar number
SOURCE: difficulty
please see web site www.eserviceinfo.com hitachi model no c-3390fsp tv component detail &circuit design for more details of ckt diagram thanks
SOURCE: hitachi rear projecton tv
your model uses two STK392-110 Convergence ICs. Hitachi also recomends replacing the feed resistors which are two 2.2 ohm 1watt, two 1.5 ohm 1watt, one 3.3 ohm 1watt and one 1.8 ohm 1watt resistor. You can get repolacement ICs and resistors at the following link and they provide step by step installation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Next you need to check if the LINE output transformer has failed. If so this will have a higher current drain and so switch off the SMPS unit. check for the EHT drivers, capacitors in the HT circuit.
