Eizo FlexScan T 566 17" CRT Monitor Logo
Posted on Sep 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Smps not working
Cheacked almost all components except STR F9202LB this STR is not available. There is no short circuit on outputs. Can u guide or provide circuit diagram for the same.
  • Shekharlko Oct 11, 2007
    circuit diagram is not available for this mode at www.serviceinfo.com
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 23, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1501
Points
Smps is not working
Anonymous
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 556 Answers
  • Posted on Sep 27, 2007
Anonymous
Expert
Level 2:
Prodigy:
Answers
556
Questions
0
Helped
173166
Points
916
As per circuit diagram is concren please check www.serviceinfo.com
LG tv str w6754 glows and short. power supply is not working?
Replace that STR. Before replacing, check all the related component/s at the SMPS section [HOT] side. any one damaged component will make the replaced STR to fail. If you wish to get some details; check the site linked here. Pull up older posts.
SMPS Circuit diagrams [STRW6754] of many popular brand TVs and other devices are given.
Search the site by type in the "BRAND NAME" or the STR number; of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1helpful
Lg crt tv str 6654 used smps output more than normal str, coupler changed but no result
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
2answers
What could be a cause of my sony trinitron 21''crt tv it's problem is fuse burned and STR is shorted when i change it it burned and shorted again ?
If STR is found damaged, you should check all the assciated components with it; like resistors, zener diodes etc: before replacing a new STR. All such components should be checked individually [out from the circuit]. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
1helpful
Sony crtv. Does not come on.Even power led is off. Sometimes it comes on and works well. But put it off and restart it will not come on. Repeatedly pushing the on switch on and off works some times.
Your TV need a through check up. From its power On-Off switch to its main SMPS section circuit are suspected. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
STR 6707 give output voltage more than 110 voltage of TV Onida model BLACK
Check it with load. If it shows more than 112VDC, the IC is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check all the related components at the SMPS section circuit, before replacing a new IC.
3helpful
3answers
Model Sony KV-G21q2S Problem-STR 6707 has been changed. After an hour the went down. The fuse and STR 6707 are working. But no picture no sound. When plug in it gives "boo" sound for few...
This is the SMPS Power suply drive and the IC fails ONLY if there is fault in the circuit. You need to check on the SMPS section
check this link below for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Next you need to check if the LINE output transformer has failed. If so this will have a higher current drain and so switch off the SMPS unit. check for the EHT drivers, capacitors in the HT circuit.
My Sony STR-DE185 is displaying "PROTECT". The manual says it is from a short circuit. Are there any known common problems with this unit related to short circuiting? Mike
If the speaker wires shorted together, it will trigger the protection circuit. If the output transistors/IC shorted out in the power amplifier section, it will also go into protection mode also.
Try disconnecting all the speaker wires to see if it will come on normal.
to have it fixed by the shop may not be worth it.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Hitatchi 42pd5000 will not power up
pls. open H-output trangister and out side of pcb and check voltage B+ 135v dc is ok ?.
if yes.then ...H-OUTPUT trangister checked and replace
if not then check SMPS .
1.fuse
2.STR
3.output Dyode
check
1st fuse is open then check rectifier dyode cantunity. if sort then replace all 4 dyode.(rectifier)
and if dyode is ok .then check STR cantunity is sort then Replace with New STR but 1st 220uf/450v dc capaciter cheked / 2nd. in SMPS stage any P.F and capciter likage or sort cheked or chenged first after the NEW STR use
*. note: smps pcb checkd any dry canaction pls. Resolder first.
1helpful
2answers
SONY STR DE525
nothing is connected at this time no speakers or in puts.....
posible component failure???? any common check points..this thing is pretty webbed with them
2answers
When power on it only shows protector and it doesn't work
The output transistors are probably defective. These are MN and MP transistors available from Sony and run about $12 each. There may be other components in the output stage that need to be replaced as well. Expect about $25-$40 in parts plus the local labor rate.
Dan
Top Eizo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Eizo Computer and Internet Expert? Answer questions, earn points and help others
