Do not try this unless you have a low power (30 watt) soldering iron and have some soldering skills.Buy some desoldering wick at Radio Shack. Place the wick on the solder connection and then place the soldering iron tip on the wick. Wait until the solder is sucked into the wick and completely clears the connection of any solder.Once both connections are clear of all solder, remove the IR sensor and place the new one in. Leave the new IR sensor leads long until you have soldered the connections. Then clip the leads short. Do not leave the solder iron on the connection to long when soldering in the new IR sensor. If you get the new sensor to hot it may damage it. Good Luck !
