SOURCE: reheating doesn't work
Hi There!
The magnetron may be faulty. When measured there should be no reading between one of the terminals and the outer case of the magnetron. Also check High Voltage Fuse( Normally a red wire with a white plastic capsule in the centre) and the High Voltage Diode(Situated between earth and High Voltage Cap). Be sure to unplug from Mains before working on the unit.Good Luck, JUS004
SOURCE: MICROWAVE WON'T HEAT OR COOK
Sorry if you misunderstand, but I offer free advice so you or someone you know can fix things yourself.
Chances are you have a bad magnetron or other high voltage part, but I won't bother you with details now.
You take care of yourself.
SOURCE: my samsung microwave oven mw5470w
Check the Ac fuse on the power board in side the over.If it is blown off replace it
