Samsung microwave...after using the "beverage feature, the E-13 message shows...I can then...
(More)
Samsung microwave...after using the "beverage feature, the E-13 message shows...I can then clear it and it's okay. Is there a problem?
microwave was running and suddenly the power shut off and now there is nothing and the outlet is...
(More)
microwave was running and suddenly the power shut off and now there is nothing and the outlet is fine
We have a samsung over the range microwave,does the vent grill on the top have to be exposed past...
(More)
We have a samsung over the range microwave,does the vent grill on the top have to be exposed past the cabinet if we are venting to outside?
proper wiring of samsung SMH7178 microwave capacitor. one resistor to ground,one dual orange stripe,...
(More)
proper wiring of samsung SMH7178 microwave capacitor. one resistor to ground,one dual orange stripe, one white
The microwave could be in "Demo Mode" - Check your owners manual. In Whirlpool/Kenmore models this is indicated by a lower case...
written by ptishkevich
If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor,
the rectifier diode.or the magnetron.
The...
written by ginko
A microwave not heating up is caused by one or more of the following -
1) Failed controller board (unlikely if you are getting a clock readout
and...
written by MrMark52
Problem: Totally dead oven.
Possible causes:
No power to outlet (blown fuse or tripped breaker or GFCI).
Blown main fuse - likely due...
written by sweet_rascal
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I...
written by UNCLEMOE
I was also told that I would have to pay a technician to come out to replace the interior light bulb in my Advantium speedcook microwave, but after...
written by kersti
What can go wrong
The most common problems occur in the microwave generating portion of the
system, though the controller can be blown by a...
Splatters of food from microwaving look bad, smell bad, and decrease the efficiency of your microwave. Fortunately, microwaves aren't hard to clean if...
by wikihow
