The first time I plugged it in it only had 4 of 5 discs in it and was able to select a disc to play and it worked. Then I tryed to eject the cartridge disc holder and put another one in, but it won't eject.
SOURCE: JVC 5-Disc Player XL-F115
You won't get any sound unless you connect your CD player to an appropriate input on your amplifier (any but phono or tape/md) and connect your speakers to this amp.
Shout if you need more help.
SOURCE: jvc xv-s332 dvd player won't play
on the back is a seitch labelled ntsc/pal. flick it the other way might fix it
SOURCE: onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
SOURCE: dennon 3930 dvd player unable
For DENON DVD-3930: In "setup", HDMI sound settings have to be "2-channel". Then SACD 5-channel output is enabled.
I was able to pull/jimmy the cartridge out and take a peek into the slot. Doesn't look like there is a CD or anything in there. But it still won't play or eject when I put it back in. Guess you were right and it'll need some disassembly one way or another. Thank you :)
