NHT SubOne makes a loud 60Hz hum (for about 4 seconds trailing off to quiet) when the standby mode is activating and when playing movies or music there are pops and crackles when the volume gets louder (maybe clipping). What do I need to fix? edit: I attached the driver (speaker) to another amp and it worked fine, so the problem is in the circuit cards somewhere. While amping, I checked the +13V on the high side of R33 (read +14.8V) and -13V on low side of R67 (read -14.5V).
Hums are generally caused by electrolytic capacitors that have gone. You should replace any large ones in the power supply section of the unit.
Testimonial: "Thank you"
SOURCE: Vizio 42" LCD HDTV audio issues
First of all go into the audio menu settings and turn off the "surround" feature off and that should fix the voices/music differences. Does the craking sound appear while watching any sorce such as cable box,sat rcvr or DVD player? If not isolate it to that input and maybe that device is giving the problem.
SOURCE: Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection. Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out. See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
SOURCE: Dell Inspiron 530 + Vista music sound popping crackle
check you speakers or try reinstalling the sound drives
SOURCE: Bose Sounddock - Speakers have a loud hiss at low song volume
Here is how I fixed the hissing noise in my Soundock;
--Pull the bottom plate off (It is attached by 4 screws)
--There is a green motherboard with 2 ribbonwires. .
--One of the ribbonwires (the one the mounts the ribbon vertically) had loosened up.
--Use a tweezers to pop it back into place and that noise will disappear.
This is a design flaw, as the action of inserting/removing your ipod, coupled with the action of setting your sound dock down will work this ribbon loose.
SOURCE: Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
The SubOne is a very complicated and dangerous amp to work on. High voltage is present even hours after being unplugged. I've been zapped more than once. If you still want to try to fix this, here are some things to check:
1. Electrolytic capacitors in power supply, 1000uF, 470uF etc.
2. Solder connections on DIN connector.
3. Trimpots on +/- tracking voltage
4. Output transistors and/or bad FET's in the tracking voltage convertor.
THIS AMP CAN KILL YOU!! BE SURE TO DISCHARGE THE LARGE POWER SUPPLY CAPACITORS BEFORE WORKING ON THIS!!
