Broiler & oven work, when its shuts off, if you put flame to broiler burner it lights but just barely. I had replaced the electronic control because it had burnt out. with no electronic control hooked up there was gas leak just at broiler.there was no gas leak before changing electronic control. I installed new control & can use oven & broiler now.
SOURCE: Hotpoint Gas oven doesn't light
Sounds like the oven ignitor is weak. If everything else is working it must be a bad ignitor. These are usually easy to replace and can expect to pay $70-$100 for the part. Check to see if it glows when in bake mode first. If it does then replace the ignitor. You can look at the ignitor, when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced. Let me know if you have further questions.
SOURCE: Magic chef oven
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
