20 Most Recent Hotpoint RGB528 Gas Kitchen Range Questions & Answers
just install a new valve
Hotpoint RGB528... | Answered on Jan 27, 2019
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Hotpoint RGB528... | Answered on Jan 20, 2016
Natural gas, they tell us, is clean burning. Well, it makes good ad copy, but it's not 100 percent true. There are trace impurities in gas, and when they burn they become ash. And over a long long period of time this ash can build up and clog tiny gas orifices, like pilot orifices. The symptoms may be that the pilot will not stay lit, or blows out too easily.
There is also a little "cup" around the pilot light in a surface burner to regulate air for proper combustion of the pilot flame. These can get covered with ash or clogged up with spillage from the burner (see below.) Make sure you clean the pilot area thoroughly.
You can usually clean them out with an old toothbrush and some compressed air, but pilot orifices are generally so inexpensive that it's cheaper and safer to replace them. If you choose to clean them out, use a soft-bristle brush like a toothbrush, and not a wire brush. A wire brush might damage the orifice. Be careful not to push the ash into the orifice and impact it.
The surface burner jets are a different animal. The problem is, that pot that boils over can leave some pretty crusty stuff on the burners. The challenge is to get that crusty stuff off without enlarging the gas holes. Sometimes the crusty stuff is not crusty but gummy, and this can be even more fun to get off the burner.
There's no magic way to do this. Depending on what's clogging the gas holes, you may be able burn it off, or at least char it so it can be scraped or knocked off. Use a propane torch or one of the other stove burners if you can get it into the correct position.
You may also be able to use alcohol or some other non-petroleum solvent to knock it loose. If you do, make sure the solvent is completely gone before you put the burner back into service. (Petroleum-based solvents might leave a residue)
Try poking it out with a straight pin if possible. You can use a welding tip cleaner, or a small twist drill, to poke into the holes but only if it fits in the hole with plenty of clearance. Do not use a drill motor with a twist drill; just push it in and out by hand. Use it as if it was a file. Use a twist drill or tip cleaner that is MUCH smaller than the diameter of the hole. Do not use anything with a remote chance of enlarging the hole. Remember, the objective is to take off the crusty stuff without taking off any of the metal. Sometimes a gas stove burner is just too badly clogged, or the holes are too small, and the burner must be replaced.
Hotpoint RGB528... | Answered on Oct 20, 2013
Here is the new igniter to order for that unit.
There is also a video on that parts page to show you how to make the repair.
Hotpoint RGB528... | Answered on Feb 20, 2013
did you change from gas to Ip .what is the problem?
Anyway if you have some trouble get support ONLINE chat from Hotpoint for you requirements.
God bless you
Hotpoint RGB528... | Answered on Oct 03, 2012
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hotpoint RGB528... | Answered on May 10, 2011
The burners are clogged and air/oxyben is not getting to the flame.
Hotpoint RGB528... | Answered on Feb 12, 2011
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Hotpoint RGB528... | Answered on Oct 04, 2010
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Hotpoint RGB528... | Answered on Sep 30, 2010
Just because it glows that does not mean it is not bad...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Hotpoint RGB528... | Answered on Aug 18, 2010
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Hotpoint RGB528... | Answered on May 15, 2010
Your problem is that when you use propane you will get the yellow burn, this is because of contaminants getting into the flame from the air, ever notice how when you light a Lighter its blue at the bottom and yellow on top? same concept. Did you by chance change the Burner heads? you need to make sure that your regulator and your Burners are rated for Propane.
Propane requires a different size orifice than natural gas and that is why it seems like its burning out of control, also when the contaminants burn it increases the size of the flame, this will leave black carbon deposits on your pans and essentially ruin them \
again back to using a lighter Just so you understand and can see the effect take 2 spoons and a lighter
Start the lighter and with one spoon Hold close to lighter so that you dont get a yellow flame, and with the other hold it at the top of the yellow part of the flame
hold them there for about 20 seconds
then look at spoons. Just so you know something that you can show to others to explain why your must change the pressure regulators and the Burner's
Hotpoint RGB528... | Answered on Jan 05, 2010
Is all the air purged out of the lines properly?
Hotpoint RGB528... | Answered on Jan 04, 2010
The fuse is in the harness and will be a fatter portion of wire. It is not recommended to use a GFCI protected circuit for the spark type ignition ranges. If it did or does work consider yourself fortunate.
Eric
Hotpoint RGB528... | Answered on Sep 29, 2009
Download the manual from here and go to page 10 for the clock settings:
http://genet.geappliances.com/DocSearch/pdf/39-4759B.PDF
Hope this helps!
WizardRepair
Hotpoint RGB528... | Answered on Jul 17, 2009
You can change the dip switches, but you may also need to work on the gas valve
Hotpoint RGB528... | Answered on Mar 09, 2009
Hotpoint RGB528 Gas Kitchen Range Logo
44 questions posted
Top Hotpoint Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Sal De
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Kitchen Ranges
Most Popular Question
broil workes but bake dont work
  • Kitchen Ranges
