Error 990 refers to the toner capture sensor unit, that black knob looking thing on the toner cartridge itself. I'm betting the error popped up right after changing the toner cartridge?..... therefore, it's a defective toner cartridge.
Have to checked to see if your exposure compensation settings are set to way underexpose your images? This will override all settings and darken your photos. Does it do it when you have the camera set on auto and/or manual? If not, and the images don't come out in the camera and on a computer then there may be an issue with the auto aperture in the lens. Try a different lens and see if it persists. There could also be a shutter issues but you'd usually get an error message with both these problems.
Hiya, you can try cleaning the belt with iso alcohol or meths and also the platter and motor spindle. Make sure clen, flip the belt over, if that fails try a new belt, and if still not then the fault is electronic.
try cleaning the inner ring on the underside of the actual turntable platter and also the motor spindle using isoprynol alcohol or use neat clear spirits like bacardi/vodka with cotton wool etc. if black residue comes off either the platter or the motor spindle that will be residue from the old belt that could cause the fluctuation in speed? good luck.
To take night photo's you need to use a tripod. this will enable you to take long exposures without the blur.
If you use flash it will only illuminate objects near the camera.
I ordered new Capacitors for my DVD Player 2 Panisonic 1500uf 10v 105° caps and 1 Panisonic 1000uf 10v 105° cap and soldered them into the powersupply where the oviously swolen / leaking capasitors were and walla it powers up and no more high pitch noise but I can't get it to eject the cd or anything. It shows on the screen but it just says loading. My guess is it did some dammage to other components inside the machine. I suppose it was worth a shot but now I am going to toss it and get a name brand. ILO isn't in business anymore... Oh and yes I did try the reset button abov the DVI connector...
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
