SOURCE: cant remove the filter grate from jetsetter spa
Ok, I can sort of solve this... According to the local hot springs dealer, there is a special tool you need to open the grate, however, they cannot seem to to locate one for sale. The part number no longer shows up in their system, so I am screwed with the same situation :(
SOURCE: Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
SOURCE: Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
SOURCE: older catalina spa with top controls showing two
Please provide your catalina spa model and year, as well as the spa control system info... You can contact us directly at [email protected]. we are a Catalina Service Center and can help you troubleshoot this
