SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
Try different locations. The sensor must be over a vain to pick up the pulse. Locate the point on the cuff where the sensor is, and place this over the elbow. That should work. Good luck.
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Testimonial: "Sound advice."
SOURCE: How do you set the time and date on a Welby Wrist
I was able to do this by 1st pushing and holding the M button and then pushing and holding the on button and holding both for 3-4 sec. Once released you will see the month flashing. change by pushing the M key to desired month then toggle to day etc with the on button
SOURCE: Where can I get a replacement cuff for our Sunbeam
need a cuff for model 7650 sunbean blood pressure monitor. where can I purchase one?
