Front panel display dim, can't see the
I see this post has been here for quite some time. Sorry you haven't had an answer yet, while I can't say why, If you still are inquiring, the problem lies in the control and harness assembly. In my professional experience with almost all thermador of this era it's sometimes a bad solder on the control pin connector from the display,(which can be fixed by a proficient soldering person or conversely destroyed by a poor one) a bad transformer integrated onto said control, or other times just a bad harness, you'll likely need a control in any event. When you purchase a control ( # 1051714 for 302-double or 1051712 for 301 single oven models, and around $200US check your local parts depot or service center.) they should have new harness enclosed in the packaging of the control.
I just joined here less than a month ago, so I'm starting to see alot of post's I haven't seen before (there are many) and likely some may never get answered directly, but alot are the same if you search out similarities.
hope this helps.
**I should add this could be a job for a professional tech, who depending on how proficient they are or how the environment is set up, could handle this in 30-45 min or so. It is quite straight forward for one experienced with servicing thermador units. I would suggest you insist on an authorized b/s/h tech, they tend to have more of the update info if any or reworks etc.**
The above (re: hiring a tech) is just my opinion based on my professional experience and there may be opposing opinions, in the end you are the authority.
hope I've been helpful to you,
Good Luck
