Acer Aspire 3000 Notebook Logo
Posted on Jul 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Half of my kebord gives numbers ! Please help i have to pres the fn button for it to work how do i fix this and where is the num lock button ?
Karan Sethi
Level 2:
Sergeant:
Habit-Forming:
  • Expert 158 Answers
  • Posted on Jul 24, 2009
Karan Sethi
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
158
Questions
0
Helped
48882
Points
506
Need to Press Num lock key. this key will be on the right side of the keyboard. It can be on a key which has 2 options aswell. Try looking for it. Press that key and check the light on the system which says number 9 or says Num Lock. The light should be OFF.
Cosma Papouis
Level 3:
Master:
  • Master 409 Answers
Cosma Papouis
Master
Level 3:
Master:
Answers
409
Questions
Helped
117033
Points
1164
Go into the BIOS and find the setting that says "Num Lock on at power on" and turn it off.
1helpful
Half of keyboard typing numbers instead of letters?
swith back num lock
usually it's FN button and num lock button
2answers
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
3helpful
Some key of my keyboard doesnt work and others one arent in correct place eg:when i press m it types 0
Turn off Number Lock
Press FN key which is blue and then pres the button where numlock is also written in blue
It will disable num-lock
Most people turn on num lock when using external keyboard but useless on a normal laptop
1helpful
A few days ago when I was on the the laptop anytime I pressed the letters mjkluio , numbers would appear instead. I tried to press the num lock button and it made no difference. Nothing would fix it so I...
The Function keys up top will not do anything when not in a program that has them set.
The num lock key on most laptops does not itself work: it must be pressed in conjunction with another key. This is normally the "FN" key at the lower left.
Please try pressing the "FN" key while you press the "num lock" key and see if this now works.
-halfs
2helpful
I have a Compaq Presario CQ60 laptop and was told that I had my scroll lock activated because the numbers on my number pad only half work. The 0, ., 4, 5, 6, /, *, - all work. The 1, 2, 3, enter, 7, 8,...
Find 'fn' key (this is short for function) then find 'num lock' key in your case it must be another key with and extra label with the same font color as 'fn', this means this key behaves differently when pressed with 'fn'. When you have located both key press fn+num lock a led indicating that numeric lock is activated should go off and you're done.
Laptop keyboard is not working correctly
Accoring to the problem you have mentioned i am sure the keys are not connected properly. The tab key is connected on the Caps lock key. Moreover make sure you press the fn key to check for any changes as it is the key which helps you toggle in Laptop
3answers
Keypad
You're kind of vague on your problem. If it's the smaller blue numbers for the calculator, you will need to use the function (fn) key. Hold the fn key and press the key the reads number lock (num lock), this should return the keys back to letters. You can find more info on the fn key and numbers lock under help in the start menu. If this isn't your problem, be more specific, and I'll be more than happy to help.
47helpful
5answers
Where is num lock button on Gateway MA7?
Fn+Scroll will toggle the Num Lock
The ison on the keyboard is a purple Lock with the number 1 inside.
1helpful
Only half my letter's work!
you are correct, the number lock is on, use the blue "FN" key and in blue under the "ins" key you should see "Num LK" push the two together and presto, normal keyboard
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
