SOURCE: GE XL 44 GAS OVEN
The valve is probably faulty, even if the gas comes out it probably doesnt have right pressure. the owen as it is may be dangerous, I suggest having it checked by a qualified technician.
Regards
SOURCE: SEARS GAS STOVE MODEL#79072114100.OVEN WONT
i had the same problem ( ignitor glows but no gas) on sears model
79071012300. i replaced the ignitor (glow bar) and the oven lit within 10-15 seconds! it was easy to replace and it took longer to figure out how to get the broiler drawer out of my way than it took to replace the ignitor.
SOURCE: gas will not stay ignited
could be dirty heater you have to clean the runners and the smole nozzles that are in the manifold below the gas valve it's like a 9/16 size you pull them off and check make sure they are clear through, sometimes little spiderwebs build up inside them. if it's all clean, then it could be you flame rectifier/ aka: flame sensing rod, that tells the htr that there is fire so it keeps running. Let me know what happened.
John
You have a bad flame sensor. Replace it.
SOURCE: Goodman GMP075-3 ignition problem
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
