I want to save the speaker but want to know what are their wattage.
SOURCE: amp works but no sound from sub
Some older Pioneer radios require you to connect the Subwoofer RCA to the rear output on the back of the radio and then you have to turn on the subwoofer in the menu on the radio. What model Pioneer radio is it? Also, make sure that the RCA plugged into the amp is on the input side, not the output side.
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
SOURCE: I have a pair of mtx pa speakers (1 12 and a horn)
Meter r040 on the crossover board, Check it for a short. It is a surge protector that will short similiar to ac power surge protectors,
SOURCE: I have a Crate PA-8 4 ohm 150 watt PA head that I
150 watts should be easily handled by four Peavey speakers in the connection you described.. If the Peavey's are 8 ohms, then your total load was 8 ohms for the series/parallel arrangement which is well within the 2 ohm drive capability of the Crate according to specs.
I question if you really mean the speakers were in series? This requires a special cable to do this. Now if you mean they were "daisy chained" like the amp went to one speaker and another cable connected that speaker to another, then you REALLY had ALL speakers in parallel electrically which would be at the 2 ohm low limit of the amp... In either case, with only 1/4 of the 150 Watts to each, the speakers should NOT have been damaged. The amp MAY have been damaged. Try each speaker individually at a REASONABLE level to test.
If you plug into the effects loop out jack,OFTEN the connection to the internal power amp is broken so you might have to arrange a special cable as a wye to go back into the power amp as well as your external amp. In any case pwere ALL interconnected amps, etc from the same power source/receptacle for system safety.
