20 Most Recent Zenith Z115S Clock Radio Questions & Answers
2answers
Zenith Z212G radio, Need preset modification instructions
Zenith Z212G radio, preset modification instructions
  1. Display desired station
  2. Press Memo Set button to make "Memo" flash on display
  3. Select desired preset number
  4. Press Memo Set button to save
3/26/2020 8:51:56 PM • Zenith Z115S... • Answered on Mar 26, 2020
Volume Control erratic. Doesn't stop when you
I used compressed air to blow out the spaces around the buttons and now it works like it is supposed to.
1/4/2010 2:55:00 PM • Zenith Z115S... • Answered on Jan 04, 2010
0answers
I have a Zenith Z50P3, and I'm attempting to connect a newer Soundbar to it. Anyone know how?
It is an old 2007 Set. Upgrade the television, the soundbar has left it behind in software terms. https://www.manualslib.com/manual/646773/Zenith-Z42p3.html#product-Z50P3%20and ..
3/9/2023 4:03:06 AM • Zenith Audio... • Answered on Mar 09, 2023
Can anyone help me fix some record players?
It's possible that there could be a problem with both record players. Here are some things to check: For the Swingmate Concert Hall Automatic Record player:
  • Check to make sure the power cord is securely plugged in and that the outlet it's plugged into is working.
  • Check to see if there's a power switch on the back of the record player that needs to be turned on before the main power switch can be activated.
  • Check to see if the main power switch is stuck or blocked in some way. If so, try gently pushing or pulling it to see if it will move.
For the Zenith 4 speaker stereophonic record player:
  • Check to see if the knob is stuck or blocked in some way. If so, try gently pushing or pulling it to see if it will move.
  • Check to see if there's a safety mechanism preventing the turntable from starting up. Some record players won't turn on if the tonearm is not in the correct position or if the record player cover is not closed.
If these suggestions don't work, it may be best to take the record players to a professional technician for further inspection and repair.
2/26/2023 6:25:40 AM • Zenith Audio... • Answered on Feb 26, 2023
Zenith ZG120W. Old am/fm clock radio flashing..
Some have a backup battery in the back or the base. Flashing normally is an indication that here has been a power cut.
1/25/2022 3:51:23 AM • Zenith Audio... • Answered on Jan 25, 2022
3answers
Need manual for vintage zenith 7050 receiver
Sounds like a bad potentiometer Here you go. Click here: https://www.hifiengine.com/manual_library/zenith/mc7050.shtml
9/14/2019 11:19:01 PM • Zenith Audio... • Answered on Sep 14, 2019
Where can I get a User Manual and Guide for my Zenith Z358 Clock Radio?
Seems impossible to find. There was directions posted on FixYa which gave directions to a different Zenith models. While not the same, you may find the directions to this model similar to your Z358.
http://www.fixya.com/support/t23768010-set_time_zenith_z1233ba
6/30/2019 3:22:05 AM • Zenith Audio... • Answered on Jun 30, 2019
Zenith clock radio Z212B setting memory buttons
Press "display" and make sure the radio is displaying frequency, not time. Tune the radio frequency you want to add to memory. Press "Memo Set" and observe that "preset" flashes on the display. Press the number of the memory channel that you want to save to. Press "Memo Set" and observe that "preset" on the display has stopped flashing. The frequency is now saved the selected channel.
3/27/2019 3:19:15 AM • Zenith Audio... • Answered on Mar 27, 2019
My zenith surround goes into protection mode after 15 minutes no sound
Disconnect your speakers when unit off and cold. Turn unit on and wait. If unit stays on, check speaker wiring for damage. Connect one speaker at a time with unit off and retest to find either a bad speaker or output channel problem. Repair speakers and wiring if found, or take unit for service, you have an overload problem.
11/22/2017 6:50:10 PM • Zenith Audio... • Answered on Nov 22, 2017
Zenith Z115S Clock Radio Logo
5 questions posted
Popular Products
Top Zenith Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Audio Players & Recorders
Most Popular Question
zenith z212g radio need preset
  • Audio Players & Recorders
