A
Anonymous Posted on Mar 09, 2014
How do you set the time on a Zenith Z1233ba - Zenith Audio Players & Recorders
GENE SMITH
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 05, 2015
GENE SMITH
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3434
Points
March 5, 2015.
I'm selling these Zenith Z1233BA Clock Radios
on ebay. I have sold about 10 without any problems, but someone just ask if I know where the get the instructions. I could not find the manual online.
Here are some of the basic.
To set the time set the lock button on the bottom to off, press the clock button, the clock will flash then use the set buttons on top to change the time. Use the <> to change the time, when the time is set press and hold the enter button until you hear a beep. You have to cycle through all the minutes to get to the next hour. Do the same to set the zone. And to set the Date select the CAL button and do the same as setting the time. Put it back on lock when the time, date and zone are set.
To set the Alarm press the Alarm Set button then use the set buttons on top change the Alarm time. Use the <> to change the Alarm time, when the Alarm time is set press and hold enter until you hear a beep. Press the Alarm On/Off button to select radio or buzzer for the alarm or alarm off. To set the PRESETS tune the radio to the station you want to be a PRESET, then press and hold a PRESET button until you hear a beep.
Zenith ZG120W. Old am/fm clock radio flashing..
Some have a backup battery in the back or the base. Flashing normally is an indication that here has been a power cut.
Need help to present stations on my zenith z1233ba
1) tune the desired station frequency
2) while the frequency is being displayed, quickly press the memo set/clock adjust button.
3) press the desired preset button
4) press the memo set/clock adj button again
5) the station will be stored
2answers
How do I present the stations on my Zenith Z1233ba?
To set the Alarm press the Alarm Set button then use the set buttons on top change the Alarm time. Use the to change the Alarm time, when the Alarm time is set press and hold enter until you hear a beep. Press the Alarm On/Off button to select radio or buzzer for the alarm or alarm off.
http://portablemedia.manualsonline.com/support/zenith/clock-radio/zenith-1233a-how-do-you-set-the-time-on-the-clock-4514622
Zenith clock radio Z212B setting memory buttons
Press "display" and make sure the radio is displaying frequency, not time.
Tune the radio frequency you want to add to memory. Press "Memo Set" and observe that "preset" flashes on the display.
Press the number of the memory channel that you want to save to.
Press "Memo Set" and observe that "preset" on the display has stopped flashing.
The frequency is now saved the selected channel.
1helpful
2answers
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
1helpful
Set Time
that long snooze button on top lifts up and the time and alarm buttons are there to set it with...ive had a zenith clock radio just like it for over 10 yrs.. have fun,..
18helpful
2answers
Zenith Z212G radio, Need preset modification instructions
Zenith Z212G radio, preset modification instructions
  1. Display desired station
  2. Press Memo Set button to make "Memo" flash on display
  3. Select desired preset number
  4. Press Memo Set button to save
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
9helpful
Need operating manual for Zenith Model Z253W radio
1. Tune the radio to the frequency you want to preset, using the "Tuning/Set" buttons.
2. Press "Time Set" button to enter set mode. Note it says "Preset" below this button, because it is used to set both time set and presets.
3. Select the preset number you want, using the "Preset" buttons.
4. Press "Time Set" button again to exit set mode.
5. Repeat the above process for each preset.
3helpful
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Top Zenith Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
