Refrigerators Logo
Daniel gibson Posted on Apr 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where to get metal arm for I'cemaker for he profile side by side fridge
John Tripp
Level 3:
  • Refrigerators Master 4,656 Answers
  • Posted on Apr 04, 2017
John Tripp
Level 3:
Answers
4656
Questions
Helped
1679249
Points
14883
Before you get anything for that refrigerator you need to begin with the model number found in the fresh food section on the wall
1 Related Answer
Anonymous
  • 998 Answers
  • Posted on Aug 17, 2009
SOURCE: fridgedare ice maker not making ice... side by side fridge
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
How do I shut down the water flow to the ice maker
There are three ways.
1. Shut water off to the fridge via plumbing valve.
2. Lift arm on ice maker or use on/off switch depending on ice maker model.
3. Unplug ice maker wiring harness. It won't be able to call for water.
It depends on why you want the water off. A make and model of the fridge would help so I can give you a more specific answer.
Ge fridge is not making ice at all
Make sure the wire arm is in the down position. If it is in the up position this signals the icemaker that the bin is full and icemaker shutsn off. Hope this helps.
2helpful
Makes too much ice and it overflows
You cannot - this is a design issue that really cannot be fixed since the arm that senses the ice level cannot get caught up in the bucket or it would break every time you opened the freezer. Any fridge brand of this type has the same issue.
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
1helpful
Ice dispenser is only giving crushed ice
Pull the ice bin out then reinsert it into the slots until it locks in place.
There is a metal arm under the ice bin. It must go inside the yoke in the rear wall of the freezer.
1helpful
Fridg is making ice (ben is full to capacity) but does not dispence propperly, it is crushing cubes and is frosting up.
The ice cube bin has become dislodged from the locked position.
Pull the bin out and re-insert the bin into the frame locks.
Look underneath the bin when you push it back in. There is a yoke device in the back wall of the freezer and a metal arm on the ice bin. Make sure the metal arm goes inside the yoke.
Make sure the ice bin feels locked in place.
Water through the door but no water to the ice maker
Since you are seeing the arm up at times, ice maker is ok. Look for problem with water solenoid valve on back bottom of unit
1helpful
Humming and frosting in freezer
Your defrost has stopped. Either the defrost heater, bi-metal or the control board has failed.
Bottom Mount Fridge
if it has a feeler arm it will look like a wire the size of a metal coat hanger it is on the right side of the icemaker if it is up pull it down to start making ice
Ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
