Troubleshooting & Support
Hot Topics:
- model
- icemaker
- not cooling
- cooling
- artica
- not cold enough
- manual
- leaking bottom
- freezing
- not dispense
- fridge
- display
- bad dispenser...
- noise
- ice
- refridgerator
- cold
- freezer
- freeze
- compressor
- Refrigerator
- dispense
- sp 50l3hr fan
- temp
- troubleshooting
- maker won work
- cold enough
- water
- dispenser
- water dispenser
- View All »
Problems & Solutions
Cant switch to water
You would have to disassemble the dispenser cover from the unit and inspect the switch that controls the water function and assure that when...
refrigerator has strong chemical (like alcohol)...
The alchohol type smell is definetley a refrigerant leak in my opinion unfortunatley if it is in your cabinet it becomes a nightmare to...
my fridge is running but not cooling
Hello there, If your refrigerator is not cooling, but is running perfectly, you will have to test the defrost thermostat, defrost heater...
GE Profile 25.6 Cu. Ft.
Hi, I'm Leo First I would check the fan in the freezer. Listen to see if it is running It moves air to the ref from the freezer Then...
My GE Side by Side will not dispense water and has
Turn off the water supply to the unit. Roll your unit out from the wall. Remove the water line from the solenoid. Get a bucket to put the...
My GE side by side refrigerator model PSC25MSWA
HI no these techs are wrong, you need to change the motherboard, gas/freon leaks are less than 2% of failures on GE refrigerators. Change...
My GE side by
Ok this sounds like your mainboard is about to go out, its causing intermittment cooling issues, board runs about $150-200.As long as you...
Hi need a manual for GE Profile side x side
Go to GEAppliances.com and use your model number to search for free downloadable manual.
GE model # GSS25JFMCWW has water to the
could be a number of thing,s The device that sends water to the ice/mak is different than the door water the ice maker has it,s own brain...
Refrigerator isn't cold enough, but the...
This problem is related to defrost.The defrost cycle is not running as it should be. The other possibility can be ice blockage in the...
Freezer side essentially defrosted. puddles of
It appears you may have a defrost thermostat problem. I'll tell about the entire defrost cycle to help you understand. Your defrost...
freezer motor is very loud at times (up &
Sounds like Ice is building up and the fan blads are clicking on them. May not be something you can easally fix. Check the defrost system is...
ice maker do not make ice on GE profile
Friend! Instead explaining in words, better watch this video and follow the steps. Thanks you. If you're helped write here....
ref not cooling enough, condensor fan rotating
if the condensor fan is rotating slowly then you should replace the fan also assure that there is no ice build up on the condensor as well...
Ice maker not making ice and when it does the ices
Hi, Many times a freezer and/or refrigerator (ice maker) do not work right because of a dirty condenser coil...there are also many other...
See all GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator Solutions
Unsolved Problems
ge tfx30 freezer working fridge not
refrigerators side is not working system ck-reset show normal
ge refrigerator psc25pstass building up...
we relaced control board and now ther is condensation building up inside of refrigertor by the sensor
the freezer freezes up and the refrigerator warms...
we had a repair man come out to check everything, he changed the "mother board" in the back a little over a...
ge profile arctica PS123NGMA WW
The vegetable crisper drawer freezes my vegetables, lettuce, etc. I have tried turning up the temp to that particular...
See all GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator Problems
Manuals & Guides
TopDo you have a manual for GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel? - Upload it to FixYa!
Upload a manual for GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Specifications
TopKey Features
Full Product Name:GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Warranty Terms - Parts:1 year limited
Warranty Terms - Labor:1 year limited
Product Weight:360 lbs.
Color Category:Stainless/Stainless look
Special Order:No
ENERGY STAR Qualified:Yes
Counter Depth:No
Thru-the-Door Ice Dispenser:Yes
Thru-the-Door Water Dispenser:Yes
Water Filter Location:Internal
Refrigerator Shelf Construction:Spill-proof glass
Temperature Control Type:Digital
Water Filtration:Yes
Water-Filtration-Replacement Indicator Light:Yes
Factory-Installed Freezer Icemaker:Yes
Gallon Door Storage:Yes
Humidity-Controlled Crisper:Yes
Child Lock:Yes
Door-Open Alarm:Yes
Surface Finish:Smooth
Cabinet Side Color:Gray
Dispenser Color:Black
Door-Handle Color:Stainless-steel
Estimated Yearly Operating Cost:56
Door Swing:Doesn't apply
Product Depth:34-7/8"
Product Width:35-3/4"
Model Number:PSS26MSWSS
Height to Top of Refrigerator (in.):68-3/4
Height to Top of Door Hinge (in.):69-1/4
Depth Less Door (in.):28
Depth Without Handles (in.):32-1/4
Depth Including Handles (in.):34-7/8
Depth with Door 90? Open (in.):50-1/16
Total Capacity (cu. ft.):25.6
Capacity: Freezer (cu. ft.):9.6
Capacity: Fresh-Food (cu. ft.):16.0
Energy Consumption (kWh/year):615
Style:Side-by-Side
What's your problem?
Fix-O-Meter
24,438
24,438 people have viewed this product
- 662 people asked about this product.
- 176 people found solutions for this product.
- 20 people have added this product.
General Safety...
Pins on the...
How to fix your...
