I recently bought a van in a dealer but it's used.
It runs great it's just like new. But after i got it, it says ''perform service'' i changed the oil and filter, washed it and fixed the tires, and i don't know what to do. And today and the lights were on in the change panel. [ drive, reverse,3, ect.] i turned it off, then on, then off and still they were all on. and when it's cold it kinds of stops and goes on really fast.
PLEASE HELP ME. IT'S MY FIRST CAR.
SORRY FOR POSTING IN THE WRONG PLACE.
Hello fabiola001,
You should be able to reset the service message by following this procedure. It's in the owners manual, but I'm taking it that the previous owner(s) didn't leave the manual in the glove box like most folks do when they trade.
Anyway, here it is:
1) Press the "MENU" button until Service Interval is displayed.
2) With this feature selected, choose an interval between two and six thousand miles using the "STEP" button. Choose something different than the current setting.
3) Press the "MENU" button again, you will then see Reset Service Distance.
4) Press the "STEP" button so that "Y" is displayed.
5) Press the "MENU" button enough times to bring you back out of the menu mode.
If you want the service interval to be what it was originally, go back and do the entire procedure again using the original current setting.
Hope this helps.
Try to disconnect the battery negative cable for 10 min and then reconnect if this didnot fix your problem then your prndel switch is bad the range senor and this is in inside the trans
