SOURCE: water tank level indicator sinks to the bottom when water tank is full.
I think the float is up and down, try to take it out and turn it.
Look at the float in the other tank to see if it is same position, the rounded side should be down.
Let me know if you get it to work.
Best regards
/Mirran
SOURCE: Have a dolphin dX3- put it in the pool and it's
the hose must be filled with water. Hold the hose up to where the water shoots into the pool and force all the air out of the hose line. The dolphin should sink.. Then connect the hose to the suction side
SOURCE: My Nitro wallclimber floats on the surface and
The most likely cause is air trapped in the debris bag. Remove the bottom panel with bag. Submerge the cleaner and replace the bag underwater. Also see Smartpool's trouble shooting guide for further assistance. http://www.smartpool.com/website/manuals/NC51%20Troubleshooting.pdf
SOURCE: dishwasher did not drain all the water
Hi, The house drain is clogged...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
SOURCE: My Zodiac pacer prefers to clean the walls of the
Here are a few things that you can try to get your pool cleaner to cover the entire surface of the pool. Add return diverters or divert return inlets downward. You may need to use the Pool Pulse feature to lower your flow. You might also need to add hose weights.
