? 4:49
https://www.youtube.com/watch?v=k1qM-ZbYdWo
Dec 16, 2013 - Uploaded by CTRL Z TV
Which will take you from troubleshooting the problem, getting familiar ... Ctrl z TV, Pilot light won't stay lit up, Gas water heaterproblems, Gas water ... If your water heater has a thermal resetbutton, press & hold it for up to 4 ...
? 3:06
https://www.youtube.com/watch?v=9bdLuGKaCXI
Sep 24, 2011 - Uploaded by Mixed Martial Animations
Here's a simple solution to a common water heater problem. ... the instructions says turn off the gas valve when lighting the pilot... i... 4 Steps, Set too pilot, hold down red button, push ignitor till pilots lit, ... if the flame will not stay on no matter how long youhold the button down, your thermocouple is bad..
This symptom indicates something wrong with the millivolt system. Start by checking the wires from the thermopile to the gas valve, insuring they are all tight and in place. Check the hi limit thermostat, if you have an ohm meter it should read .1 or .2 across it. With you meter set to dc millivolts, and flame present on the pilot, read across the thermocouple wires (red and white) to see the millivolts generated, with the thermostat off and the gas valve in pilot position you should get approx 600 millivolt plus minus 50. The pilot will have to be on for a minute or so to get maximum millivolts. If the millivolts are correct, hi-limit closed, and all wiring is connected, you likely have a faulty gas valve. If the hi limit reads more than .1 or .2 replace the limit, if you are not getting the millivolts from the thermopile, replace it.
I am not familiar with this particular brand. What type of heater is it? Normal pilot lighting is done by setting the gas valve to the "Pilot" position and then pushing on the valve to manually open the pilot. After this, light the pilot and continue holding the valve for 30sec to give the thermocouple a chance to heat up. Release the valve and it should stay lit. Turn the gas valve to "On" and you're done. If it doesn't stay lit after releasing the valve, replace the thermocouple. If it doesn't light at all, call a technician out to check gas pressure, orifice, and pilot assembly.
Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
