SOURCE: ceiling fan motor locked up
replace ceiling fan motors will lock up its called normal wear
recommendation for a good strong long lasting ceiling fan
hampton bay
or hunter
my father put up fans some 16 years ago and still running strong
SOURCE: Heritge ceiling fan
you can buy this online or you can call this number and inquire about this particular plate 888-854-5483
menion your model and part name, they can surely provide you w the part you need
SOURCE: Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
SOURCE: ceiling fan does not blow air
I would guess that the blades are on upside down. Ceiling fans are not supposed to work the same as desk fans though. The idea is not to create a strong flow of air but to create a "cooling breeze" by speeding the convection currents. They work better when they are running slowly (like you see in the old movies)
SOURCE: Ceiling fan stopped working
two of my four Hunter fans/lights have quit working. I have tried both the remote control and the pull cords but no luck. Is there some way I can verify if the two units are getting power?
