SOURCE: file transfer error
firstly LG phones are well known for having a lot of problems, including music and picture transfer. I have an Lg platinum and it took me days to find out how to transfer things on to it. When transfering music make sure it is in MP3 format otherwise it won't show up on your cell phone. You may be able to purschase a link cable for your phone to connect it to the computer, try searching on the internet or go to lgmobile.com thanks morseasjack
SOURCE: Can't figure out how to make my VR3 bluetooth unit send a signal to my BlackBerry.
Go here http://safemanuals.com/user-guide-instructions-owner-manual/VR3/VRBT200V-_E
SOURCE: I have the Samsung Galaxy I7500 but cannot get its
Most samsungs comes with only A2DP BT profile, this means that it can only pair up with BT headset device. If you know how to navigate your phone, go to the BT settings and check the profiles.
SOURCE: I have samsung galaxy bluetooth not working
you need to pair it first to your laptop or computer's bluetooth before you can send any data.
do these steps..
1. open your bluetooth from your computer, make it discoverable, and select add device. open your bluetooth from your phone, in the same way, make it discoverable so your pc will search for it. once searched, select your device and click next. it will install, it will ask for a pairing passcode it's up to you to assign this both on your pc and your phone, just use 1, so you can remember it easily. once paired you can send any files from your phone to your pc.
if the phone bluetooth driver was asked during the installation, just install the pc suite software that comes with your phone and let your phone be discover again through bluetooth by your pc.
good luck.
SOURCE: My Samsung galaxy portal GT-15700 phone will not
I have the same problem with the same phone.
I bought a Zeemote (bluetooth controller) which needs to have a .sis file installed on the phone, but the phone does not recognize the file type.
Please help.
As for mefonna's problem, I usually connect my phone to my laptop, go into 'My Computer' to access the phone and just transfer files (drag and drop) across directly to your phone from there.
There is also an app you could download called 'Bluetooth File Transfer' (which is free) to transfer files via bluetooth.
