Cars & Trucks Logo
L
Lynn Foreman Posted on Feb 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you read the temperature of engine. Thanks
Bill Boyd
Level 3:
Top Expert:
  • Cars & Trucks Master 53,816 Answers
  • Posted on Feb 06, 2017
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951359
Points
172802
With a temp gauge
down the bottom is cold
in the middle is correct operating temp--85-95 degrees c or 185 F- 203 F and up the top in the red is overheating or boiling
most temp gauges are only indicators and do not report the actual temp of the engine
Level 3:
  • Cars & Trucks Master 19,187 Answers
Level 3:
Answers
19187
Questions
0
Helped
4346502
Points
82261
There are several methods. You can use the dash gauge but it is not accurate. The other ways are to use an infrared thermometer, an OBD reader, or manual gauge in the coolant
On a 2008 Ford focus why does the temp Guage read hot when the car is not hot
There could be a few different issues that could cause the temperature gauge on your 2008 Ford Focus to read hot when the engine is not actually overheating. Here are a few things to consider:
Failed thermostat: The thermostat is responsible for regulating the flow of coolant through the engine. If the thermostat is stuck in the closed position, it could cause the temperature gauge to read hot even though the engine is not overheating.
Failed temperature sensor: The temperature sensor sends a signal to the temperature gauge to indicate the engine's temperature. If the temperature sensor is faulty, it could cause the temperature gauge to read hot even though the engine is not overheating.
Wiring issue: If there is a problem with the wiring that connects the temperature sensor to the temperature gauge, it could cause the gauge to read hot even though the engine is not overheating.
To determine the cause of the issue, it may be necessary to perform some diagnostic tests and possibly replace some components. A mechanic or a professional auto repair shop will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to keep an eye on the engine temperature and take note of any other symptoms or issues you may be experiencing. This information can help the mechanic diagnose the problem more accurately
1helpful
Are there 2 coolant temp sensors on a 1996 Buick Century 3.1?
No , their arn't two coolant temp. sensors . One near the thermostat housing . The Temp sensor is a input to the PCM / ECM . The PCM / ECM needs the temp info for fuel calculations . The temp gauge on the instrument cluster gets this info over class 2 serial data network Hooking up a factory or professional scan tool that can read sensor data is the easy way to diagnose ,not guessing . Looking at factory service info. an wiring diagrams too see what is what is another way . You have no clue ,take it to a qualified repair shop.
The engine coolant temperature sensor is a thermistor (a resistor which changes value based on temperature) mounted in the engine coolant stream. Low coolant temperature produces a high resistance (100,000 ohms at -40°C/-40°F) while high temperature causes low resistance (70 ohms at 130°C/266°F).
The PCM supplies a 5 volt signal to the engine coolant temperature sensor through a resistor in the PCM and measures the voltage. The voltage will be high when the engine is cold, and low when the engine is hot. By measuring the voltage, the PCM calculates the engine coolant temperature. Engine coolant temperature affects most systems the PCM controls.
The scan tool displays engine coolant temperature in degrees. After engine startup, the temperature should rise steadily to about 90°C (194°F) then stabilize when thermostat opens. If the engine has not been run for several hours (overnight), the engine coolant temperature and intake air temperature displays should be close to each other. A hard fault in the engine coolant sensor circuit should set DTC P0117 or DTC P0118; an intermittent fault should set a DTC P1114 or P1115. The DTC Diagnostic Aids also contains a chart to check for sensor resistance values relative to temperature.
The ECT sensor also contains another circuit which is used to operate the engine coolant temperature gauge located in the instrument panel.
1helpful
Changed out water pump and thermostat and vehicle runs high temperature what could be issue?
Reasons the Temperature Gauge Reads High
If the temperature gauge reads high, it could mean your engine is overheating. Another reason your reading might be high is you could be losing coolant. A small leak or evaporation may cause your radiator to slowly lose coolant. A third reason your temperature gauge reads high could be because the thermostat is broken. If this is the case, you may need a coolant temperature switch replacement. The last reason the temperature gauge could read high is because of a water pump, or water pump gasket failure. If the water pump is malfunctioning, it may need to be replaced by a professional.
What to Do If Your Temperature Gauge is High
If your temperature gauge is reading high, it means your car is overheating. This is a very serious matter and you should never drive an overheating car. If your car starts to overheat, shut off the air conditioner and open the windows immediately. If this does not reduce the overheating, turn on the heater as high as it can go. If this still doesn't work, pull over on the side of the road, turn off the engine, open the hood carefully, and wait until the vehicle cools down. Never open the radiator cap while the engine is hot - coolant can spray and burn you. Once the vehicle has cooled, take the car to a mechanic right away so they can diagnose the problem. Cars are especially susceptible to overheating in hot climates, like what's common in cities like Los Angeles, Phoenix, Las Vegas, or Atlanta.
The temperature gauge is an important tool in your vehicle that shows the temperature of your engine's coolant. Contact YourMechanic and have your car inspected for overheating if it reads too high, as this can cause serious problems...
Reasons the Temperature Gauge Reads Cold
On most vehicles, the temperature gauge reads cold until the engine has run for a few minutes. If the temperature gauge still reads cold after the engine has warmed up, the gauge may simply be broken. Another reason the temperature gauge could read cold is if the thermostat in the vehicle stays open. With the thermostat stuck open, the engine can be overcooled, causing a low temperature reading. If this is the case, the thermostat may need to be replaced.
What does this code mean p0128 i need to know thank you it is on a pontic gran prix
Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolant temperature (ECT) sensor reading, and the speed of the vehicle.
1helpful
When I jump in my car in the mornings (cold engine) and turn on the key (without starting the engine) the cooling fans come on (outside temp is only 60 degrees).
-No not to worry about it if your car never over head.
-No you can't get any reading if the temperature is at your thermostat's setting or below.
-It connect or (Works) ONLY when the temperature at that area reach above the thermostat setting or up to 200 degree or higher.
Good luck
Mai
2003 volkswagen golf engine temperature gauge and engine light on
If the temp gauge reading is high when the engine is cold it will be a short to the sender unit or a faulty sender unit ( as opposed to a temperature sensor unit). Have the fault codes read to find out what put the engine light on ( overheat)
P0128 code on 2006 ford escape, solutions?
Diagnostic Test Code (DTC) P0128 has a generic description of "Coolant Temperature Below Thermostat Regulating Temperature".
The Poertrain Control Module (PCM) checks the coolant temperature at startup. It then calculates the period of time that it should take for the engine to reach operating temperature (or thermostat regulated temperature). After the calculated period of time, the PCM again checks the coolant temperature. If it has not reached operating temperature, a code P0128 flag is set in mode 6.
If the engine still has not reached operating temperature after 5 more minutes of continuous engine operation, code P0128 is set in continuous memory and the Check Engine (or Malfunction Indicator Light "MIL" is turned on.
Possible causes:
> A stuck-open engine coolant thermostat (MOST common)
> A skewed Engine Coolant Temperature (ECT) or Cylinder Head Temperature(CHT) sensor (working, but not reading correct temperature)
> Low engine coolant level (causing the sensor to not read correctly)
First, the engine coolant (antifreeze) level should be checked. If it is low, it is recommended to perform a cooling system pressure test to find out WHY.
Then, the actual engine temperature should be measured with an infrared thermometer near the ECT or CHT. The reading from the thermometer should be checked against the live sensor data with a scan tool. (PLease note that MOST generic OBD code readers CANNOT perform this function.)
If the reading from the thermometer and the sensor data is within 10 degrees F of each other, replace the thermostat. Otherwise, the sensor circuit should be checked for high resistance (loose or corroded connector, damagd wire, etc.). If no high resistance is measured in the rest of the circuit, the sensor should be replaced.
Po190 lincoln 2003 ls
DTC P0190 - Fuel Rail Pressure Sensor Circuit Malfunction
Check fuel pressure with a mechanical gauge and check the reading of the Fuel Rail Pressure (FRP) sensor on the scan tool.
When cycling the ignition switch from the off to the run position without starting the engine, the fuel pressure measured on the fuel gauge should match the reading of the FRP sensor on the scan tool.
If the mechanical gauge reading is showing to more than 2 psi higher than the FRP sensor input, replace the FRP sensor.
If the values match, start the engine. With the engine idling, the mechanical gauge will indicate about 10 psi different than the FRP sensor but when the vacuum line at the sensor is disconnected, the values should again match each other.
If the pressure reading matches the FRP sensor reading and the pressure is showing a reading of 30-45 psi Key On, Engine Off (KOEO) and at idle, check for a possible fuel quality issue.
Also check the engine temperature input reading from the Engine Coolant Temperature (ECT) sensor to verify it shows a believable temperature reading.
Possible Causes:
FRP sensor connector is damaged (check pins for damage, and for moisture)
FRP sensor reference (5v) circuit is open or shorted to ground
FRP sensor has failed
Vacuum leak(s) present in the engine
I hope this helps; remember to rating this and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment.
Have a nice day and thanks for using FixYa.
Jose.
Hello my check engine light is on i went to local parts house had them read the code low input voltage in the iat sensor so i bought a new one had the code cleared and before i left parking lot light was...
Keep in mind that the IAT (intake air temperature) sensor simply measures the temperature of air that is entering the engine. Intake air temperature is important because the higher the intake air, the higher the combustion temperatures. High combustion temperatures result in increased Nox (Nitrogen oxides) emissions. To keep these higher temps from causing increased combustion temps, the intake air tubing should be intact, allowing the engine to "breathe" air that isn't sampled from the engine compartment. The IAT measures air temp by using a thermistor, or a thermometer of sorts. The thermistor is supplied 5 volts reference voltage from the PCM (powertrain control module) and a ground. Usually, when the air temperature is cold the resistance in the thermistor is high and when the air temperature is warmer, the resistance decreases. This change in resistance changes the 5 V reference from the PCM, thereby informing the PCM of the temperature of incoming air. If the PCM notices that the incoming air temp is unusually high, say, 300 degrees, when the engine temp is still relatively low, it will set a P0112.
Symptoms: There may be no noticeable symptoms of a P0112 code other than an MIL (Malfunction Indicator Lamp). However, a emissions test may reveal higher Nox readings depending on the type of IAT failure. Or the engine may ping under load, depending on the type of IAT failure.
Causes: Usually the P0112 is caused by a bad IAT (internally shorted or open or otherwise damaged), but it could also be:
* No reference voltage to the IAT sensor due to an open wire
* Excessively high intake air temperatures
* Short to ground on signal circuit
* Damaged IAT connector
* Bad PCM
Possible Solutions:
Hook up your scan tool or code reader and read the IAT reading. With a cold engine, the IAT should roughly match the coolant reading, since both will read ambient temperature. If the IAT is reading excessively high, check the IAT connector for damage. If you find none, unplug the IAT sensor and recheck the reading. It should now read the minimum, around -20 deg. If it does, then replace the IAT sensor. But, if the reading is still high, unplug the sensor and check for resistance across the two wiring harness terminals. If there is infinite resistance, then the PCM itself is bad. If the resistance isn't infinite, then check and repair the short to ground on the signal circuit.
Keep us updated.
1999 chrysler voyager 2.5 td cooling fans
if i disconect temp sensor fans come on cool engine but then no temp gauge
That's what I'd expect after unplugging.
This is sounding like a bad coolant temp sensor. Test it or replace it before you do anything else. Read this post on how to test an engine coolant temperature sensor
Test engine coolant temperature sensor Ricks Free Auto Repair Advice
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
