SOURCE: screen is frozen showing only the LG symbol, occasionally flashes
with a frozen phone issue, you may need to reset the software to get it running again. But you might loose your data if you flash the phone. I hope you don't have a problem with the screen. sometimes too, when the memory space is filled up, it freezes up. Take out the battery for some hours and try again. if it does not resume, then you may have to flash the phone to reset it to factory setting. Hope this solves your problem. Cheers!
SOURCE: Power Only
On the LG TV remote, press either the "return" button or the "exit" button, then press power to turn it off and then power to turn it back on again.
Fixed!
(This happens when some other device remotes send a strange signal to the LG TV, putting it in a service mode).
