SOURCE: after i cleaned the filter, shop vac doesn't turn back on
IT SOUND LIKE THE MOTOR WENT BAD OR IN SIDE THE PANLE A WIRE CAME LOSE
SOURCE: Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
SOURCE: DEWALT DW795 Vac filters
IT looks like the part number is 429704-56 and the Dewalt site shows list price being $51.68. You should be able to order that filter at a DeWalt dealer in your area, hopefully for a discount.
Otherwise, there is here online:
http://www.ereplacementparts.com/search_result.php?osCsid=2c10ce07c62a161bca9f80f981bf690f
SOURCE: craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
