Question about Shop Vac Vacuums
I have a Shop Vac (Wet/Dry) Model 5275 (120V 60Hz 6.4A), Peak HP of 2.75 While vacuuming the Shop Vac fell over, stopped working, and would not come back on again. Tried plugging into another outlet, etc., but nothing works. Is there some internal problem that I can fix myself?
Posted by fara_casa on
Russell Spataro
    Habit-Forming:
    New Friend:
  • 8 Answers
My vac isn't a shop vac brand but my home Depot brand vac has a reset switch that acts like a circuit breaker. Look for one on you vac. There is no way any brand vac of this type should stop working just by tipping over. My vac fell down a flight of stairs and fell off a deck and still worked fine
Posted on Feb 27, 2018
Thatvacguy.com
  • Shop Vac Master
  • 1,616 Answers
Some models have a fuse that blows but it is not replacable.
4 Related Answers
shastalaker7
Robert Horton
  • 1515 Answers
SOURCE: Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Posted on Jan 23, 2010
Stephen Potts
  • 447 Answers
SOURCE: Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
Posted on May 16, 2010
caroldon
  • 17130 Answers
SOURCE: my shop vac stopped working
Staring from the failrue of the power cord,the main plug,t he main switch each of the sections must be tested for continutiy before we can conclude.
SInce it is clear case of power failure the voltage must reach the motor,if not back trace to the point decribed above.
If voltage is at the motor without any reponse then the motor can be faulty.Checked also faulty surge/capacitors.
Posted on Sep 14, 2010
small6363
  • 18429 Answers
SOURCE: Shop Vac 84M200 Wet/Dry Vacuum does it blow?
This video will show you.
http://youtu.be/-gCukdig57I
Posted on Oct 02, 2012
1helpful
I need a manual for a Sop-vac 1.5 gallon.
Have a look at this page and if it matches your product, you can click "user manual" on the right hand side to download a PDF version of the manual.
Shop Vac 1 5 Gallon 2 0 Peak HP All Around EZ Wet Dry Vac
Sep 19, 2017 • Vacuums
I have a wet/vac model 2010a 1..0 peak hp do i put the gray filter on to sick up water or to dry vac
The filter is only for dry use. When you are picking up water etc with it, don't use any filters. They get ruined.
Is there an 800 number where I can reach customer service for my shop vac?
I cannot find a 1-800 # but here is some of the contact info from their website. Hope this helps.
https://www.shopvac.com/contact.asp
United States Customer Service
Phone: (570) 326-0502xepmsfks7ymm8bsamlyf2owtpszamzmeaygcpjvaaaaaelftksuqmcc
Fax: (570) 326-7185xepmsfks7ymm8bsamlyf2owtpszamzmeaygcpjvaaaaaelftksuqmcc
Web: Send Email
Regular Business Hours: Monday - Friday, 8:00 AM - 5:00 PM EST
How do you replace the switch on a shop vac 2.0 quiet series
The switch should be connected to the power cord just use a multimeter to work out where the wires go , do you have a pic of the switch ?
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Trying to vacum and it starts to blow
There are two outlets on a shop vac one to blow and the other to vacum.
1helpful
2helpful
Sincerely,
Shastalaker7
1helpful
I need to replace a brush to operate the shop vac. Where can I find it?
true value hardware stores have books to order these parts , piar of brushes are between $3 -$7 ,also most vaccume sweeper shop
Vacuums Logo
Top Shop Vac Vacuums Experts
Mike
Steve Sweetleaf
Steve Sweetleaf
Ekse
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
