Phone hasn't been used in 2 years and would like to start using again. I've tried reset and recovery mode with no avail. HELP!
SOURCE: Iphone problem "please connect to Itunes"
restore to the latest firmware (1.1.3) and try again
SOURCE: My iPhone is disabled for 4,566,757 mintues, HELP!
The only way is to reflash a new firmware and wipe the code as well as the phone clean.
To do this start itunes on your computer. Then connect your phone to the computer. Once itunes detected your phone hold the POWER and the HOME buttons down at the same time for about 10 seconds. Once the phone flashes off, let go of the POWER button and keep holding the HOME button until you see a message on the itunes telling you that your phone is detected and needs to be RESTORED. Follow directions and it will do its job. I appreciate your positive vote. Thanks
SOURCE: iphone disabled to "connect to itunes" but needs passcode
Turn your phone off and plug it into your computer holding the home button down. That will put your phone into restore mode.
http://www.mobileease.co.uk
SOURCE: Restore Problem with iphone A1203 2g
Well, your SIM card must be compatible to your iphone carrier. From what I understand, so far only AT&T is able to give out SIMs for iPhones; however, that may have changed to the addition of another carrier (perhaps Verizon, or so I hear) If you have the correct SIM card, then I would suggest that you go to your nearest wireless store and ask for one that may help your situation. Otherwise, if you don't want to do that then just unlock your phone :) There are videos on youtube that you can look at, programs that you have to download and what not, but it's doable.... or you can take it to a side stand wireless and have them unlock it for you :)
