Question about Apple iPhone 6
My iPhone 6 is dsabled. How do I get my phone back
Posted by Jacob Underwood on
  • 2 more comments
  • William Lee
    William Lee Jun 18, 2019
    When your iPhone 6 is disabled, the only method to get it work normally is to restore iPhone. You can use iTunes or recovery mode or iCloud to erase your iPhone, with all the data gone. Or you can use professional iOS unlocker tool such as Joyoshare iPasscode Unlocker to unlock disabled iPhone 6 easily and efficiently. Here is the detailed guide:https://www.joyoshare.com/unlock-iphone-...
  • deepak
    deepak Jul 24, 2019
    if you iphone is lock and your forget the passcode but you remember Apple Id and password then swithoff your iphone press the home button while connect you iphone thru a usb to a computer the open itunes then restore it done then your ipohne start a new iphone setup and add Apple Id
  • Roger Garcia
    Roger Garcia Aug 27, 2019
    I agree. You can enable Recovery mode on your iPhone or you can simply use ApowerUnlock if iTunes is an issue to you.
  • morris white
    morris white Sep 18, 2019
    legit website which gives all methods to find unlimtied coins in homescapes game.Homescapes Cheats
Tonya Cordova
    New Friend:
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Posted on Apr 05, 2017
Marrimary
    Master:
  • Apple Master
  • 134 Answers
You may receive the message like "[Device] is disabled, connect to iTunes", "iPhone is disabled try again in 22,312,198 minutes". In this case, you need to recover your iPhone with iTunes or recovery mode, but this will erase all of your files on your device.
Forgot iPhone iPad Password Unlock Disabled iPhone and Restore Data on it
Solution 1. Unlock Disabled iPhone/iPad with iTunes
Solution 2. Unlock Disabled iPhone/iPad/iPod without iTunes through Find My iPhone
Solution 3. Unlock Disabled/Locked iPhone/iPad in Recovery Mode
Posted on May 08, 2017
How to Recover Lost Photos on Iphone?
If you are the crazy fan of Apple, you will know that deleted photos HELP NUMBER +1 833 272 0777will be saved on the DELETED folder for 30 days.
Sep 17, 2018 | Apple iPhone Cell Phones
How can I jail broken my iPhone 6
Wouldnt't recommend it!
Recovering from a JailBroken phone later on can be a pain.
You won't be able to install the updates & bug fixes & security updates.
Depends what IOS you are currently on!
Apple spend a lot of time protecting the iPhone from Virus and back door security breaches so jailbreaking takes a long procedure and lasts for one IOS only.
IOS8.2 has a lot of customisable features now
Bottom line is if you need a smart phone to play around with then get a cheap Android phone. They are made for Tinkerer's
Apr 02, 2015 | Apple iPhone Cell Phones
How do i reset iphone 6 to factory resets
On your iPhone, go to Settings, then General. Tap on Reset. You should see three different options to choose from.
To proceed, tap on Reset All Settings. Be careful not to tap 'Erase All Content and Settings'
Your iPhone's settings should be back to its original configuration without you having to lose all your data and restore them at a later time.
Feb 22, 2015 | Apple iPhone 6
How do I recover iphone 5s text messages that disappeared?
If you use iCloud to back up your iPhone, you can easily restore your phone from iCloud. And this will bring back your data, however, the existed data on your phone will be erased.
If you want to recover your messages without losing the existed data on iPhone, you can use PhoneRescue to get back the lost messages, as its name expresses, is a professional iPhone data recovery tool.
Sep 15, 2014 | Apple iPhone 5S
How can I retrieve contacts due to my phone getting stolen
I know a great way to retrieve your contacts due to iPhone stolen. Besides recovering deleted contacts from iPhone directly, iPhone users can take advantage of iTunes or iCloud to recover deleted files. If iPhone users updates their iPhone backup in iTunes or iCloud regularly, they are able to restore their iPhone with iTunes or iCloud to get the lost contacts back. Next I will show you the guidance to retrieve your contacts with Leawo iOS Data Recovery. Download Leawo iOS Data Recovery ' Leawo iOS Data Recovery for Mac and install it.
Step 1: Open Leawo iOS Data Recovery and Connect iPhone to Computer
Insert iPhone to computer and run Leawo iOS Data Recovery on computer,. Hit the option of "Recover from iOS Device".
Step 2: Scan iPhone Data
Tap "Start" button to begin to scan iPhone data. Wait until the percentage panel reaches 100%.
Step 3: Recover iPhone Contacts to Computer
Check "Contacts" tab in the left sidebar and then tick "Only display the deleted items" at the bottom left of the interface. Choose the contacts you want to recover and then hit "Open" button to set a computer folder to save the exported numbers. Click "Go" button to invoke the recovering process. Wait for a moment and you will get iPhone lost numbers on computer folder.
With this great tool to help you, there is no need for you to worry about iPhone 6 contacts missing or iPhone 7 contacts missing any longer. Applying this software to solve other recovering problems will also get the best results.
ios-data-recovery-from-device-preview-contacts-g4j5qve4215hcvtdwckgppda-1-0.jpg For more detail, check: How to Recover Deleted Contacts on iPhone
Sep 01, 2014 | Cell Phones
How do i prevent Tenorshare iphone data recovery from crashing every time i try to connect my iPhone?
I have not tried that tool before. To do iPhone data recovery, maybe you can try other tools. Usually, if the deleted or lost data is not overwritten, you can get them back easily. iPhone 6 Data Recovery Recover Lost Files from iPhone 6 6 Plus
Dec 07, 2017 | Cell Phones
Lost my contacts 200 on sim and 200 plus on phone. Any recovery
STOP! Don't try to recover your contacts yourself. You could make matters worse. Take your phone to a repair facility owned by your cellular provider. Many have software that can recover lost contacts. I've run into this before on other phones and taking your phone to a service center is your best bet. Good luck.
Jan 25, 2011 | Nokia 3110 Cellular Phone
Apple iPhone 6 Logo
613 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
