Televison & Video Logo
L
Lisda Thomas Posted on Jan 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to program haier televion model #HL32D2 with direct tv remote control but need code and which brand, other than Haier, to use because that brand is not listed on direct TV's options available.
james laughton
Level 3:
  • Haier Master 2,195 Answers
  • Posted on Jan 07, 2017
james laughton
Haier Master
Level 3:
Answers
2195
Questions
Helped
411709
Points
6636
Haier TV Remote Control Codes
0217
0157
0081
0216
Where is the fuse to the crankshaft position sensor for the 3.0si
there is no such thing ever, CKP it is hall sensor or mag sensor
yes the HALL uses 5vdc from the same named pin Of the PCM
but the PCM has regulator for that. (not a fuse ever 5V)
the PCM has 12V fuses sure. as do every computer in the car.
BCM and all.
yes all cars and all electronics, or electrics, all have fuse. of one form or another, even like door windows have CB circuit breakers.
cranks but will not start , has 50 causes./ SORRY !
a tech knows that and does check ALL FUSEs not just one ever.
what if a fuse blew and the CAN_bus network when dead.?
yes we check them all , for sure year 2000 up. for SURE>
no start (CRANKS FAST)_ MACRO ANSWER.
  1. BAD ENGINE, TOP CAUSE CAM BELT SLIP/SNAP
  2. NO SPARK, (CMP/CKP, SPARK PARTS BAD OR ABOVE1
  3. BAD FUELING , NONE, TOO LITTLE OR TOO MUCH.
#1 HAS THE MOST CAUSE,. LOOK INSIDE ANY ENGINE SEE ALL THOSE HEAD VALVE PARTS TO FAIL? LOTS.
WE HAVE TESTS FOR EACH LINE ABOVE , NO EXECEPTIONS, USING TOOLS/METERS/SCOPSES/ AND SCAN TOOLS
IF WISE AND ALL FUSE ARE GOOD
WE SCAN THE PCM FIRST (OBD2 DLC PORT)
AND FOR SURE CRANKED FOR 5 SECONDS TO SEE IT FAIL.
WE HAVE NO X3 IN USA, SO CAN NOT WAX SMARTER
AND I HATE GERMAN SCHEMATICS, (LOVE ALL OTHERS)
THEY USE GERMAN ONLY CODES FOR PARTS. GEESH.
NO ASE OR SAE NAMES, In their german world.
we have X5 but online no schematics, gotta love BMW. (not me)
if engine is good, tested (compression)
we test spark next on all cylinders, if all are dead, sure CMP or cam belt. or CMP dead, (or)
if spark is bad on JUST one cylinder a new COP coil.? boots bad?
if spark is good.we try test fuel (spray can, to air cleaner port filter out)
I spray 3 seconds, crank it and runs 3 seconds ,repeat 3 times;
if engine sounds great smile and say fueling bad.
check fuel pressure using gauge(shop) for spec pressure.
check voltage 12vd to pump cranking.
bingo
do not trust key on pump tests, CRANK IT. (yes 2 persons)
My haier tv stayed in USB mode and just froze there off and on probe responds to the control and nothing. prove with the buttons on tv and neither worked
press on you remote repeatedly the keay "back", the screen will turn blue, then press "input" and select your option, it should work.
I have problem with my haier tv with the sound and i use in antenna it dosnt have a sound
check it with your remote it might selected to mute mode, if not, its either your speaker or sound ic amplifier output..
1helpful
Tv remote code for haier tv l24c1180a?
Hello
Four digit universal remote contro codes for Haier TV are:
0081 0216 0217 0157
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
1helpful
What is the universal code for haier remote controles
Hello
Four digit remote control codes for Haier tv are:-
0081 0216 0217 0157
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
2answers
I have a haier tv with a comcast remote. Need the Haier code for the comcast remote
10768
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
9helpful
5answers
REMOTE CONTROL CODE FOR HAIER TV
We have a Haier TV model 3 HL32R2a, the cable remote no longer turns the set off or on or controls the volume. We can only do that with the tv remote. Tried putting in the universal code, and the Haier code and it didn't work. Please help.
2helpful
3answers
Remoe code for haier tv model tdc1314s
I found the 3 digit code for my Haier tv by auto search it was 226.
Top Haier Televison & Video Experts
Paul Bade
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
