Hook up a USB cable from your ipad to your computer. Download the music files and then connect the android phone the same way and put the music files into the music folder on the droid.
To transfer photos from Sony Xperia phone to tablet, it is possible, youjust need to plug your two devices with computer, and then open a mobile transfer software, it can help you transfer files like photos from one phone to other phone. Phone Transfer How to Transfer Photos from Android to Android
hi Lorraine.
this is all i could find out,if this does not work for you go to the link at the bottom. Turn the Android tablet on and connect it your Windowscomputer via supplied USB cable. 2. Click the "Open Folder to View Files" option when the AutoPlay dialog box appears.
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - 9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Here is a good site that will walk you through it step by step
http://www.androidcentral.com/how-get-your-itunes-music-your-android How to get your iTunes music onto Android
if you can remove the battery start there. is not try to hold the power button for 1min. if that still doesn't work follow the bellow instructions
When Hard Reset is Necessary for Smartphones or Tablets ?
1. Forgotten Pattern Lock on AndroidTablets or Smartphones.
2.Too many pattern attempts / Reset user lock.
3. Tablets PC,Smartphones stuck on Gmail account.
4. Android Tablet PC stuck / freeze on Android logo.
5. TabletAndroid or Smartphones hang on start-up / Multiple errors generating by OS.
6. Android market having problems or generating errors.
7.Upgrading to new Android version.
Make sure to charge battery upto 60%.
How to Hard Reset Argos CnM TouchPad Android tablet pc ?
Make sure the tablet is charged up to 60%
Turn off the tablet completely .
Press Volume + button , while holding Volume + button , plug in charger.
Release the volume + button.
Press Volume + again and press Power button to boot the CnM Tablet.
When Android logo appear , release the volume + button.
Press Power Button again and press volume + button , Recovery Menu will be appear .
Press the volume down and select "wipe data/factory reset"
Power button to select it
You will see "Yes - delete all user data"
Select "Yes"press "Power" button to select it
Formating will start. it will delete all user data .
Few seconds later, you should see the recovery menu again. Select reboot.
It will take approximately 2 to 3 minutes to take you back to its factory (out-of-the-box) state .
you are done.
This Hard Reset method will work with all models of CnM touchpad tablets.
