This fixes almost all the "beans will not feed or beans will not grind"
problems caused by coffee bean dust packed in the burrs. Oily beans
cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured
out. Use your shop vacuum to **** grounds out the spout and backward
out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to
a small setting like six and then open the settings all the way again.
(The grinder will not start at a low setting with the rice in it. If
you let it stop, open the settings to about 16 before trying to
restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind.
Grind until most of the rice dust is expelled (any remaining trace of
rice dust will not affect the flavor of the coffee).
Try this set grind on coarsest setting, then turn on, it is possible that the grounds chute is blocked. Using a courser grind might force the chute open.
