SOURCE: Shifting in drive from park position
that means the pin that the knob presses down is stuck on something. if you take the shifting panel off it showes everything. then there will be a plastic guide. see what the pin is sticking on and there you are.
SOURCE: Second controller doesn't recognize accelerate, reverse works
Try resynchornizing it to your Wii again. If this doesnt not work, you may have a defective Wii Remote. You should consider replacing if synchronizing it does not work.
SOURCE: Kenmore 15516 It only goes reverse both ways.
Does it have an automatic buttonhole? If so, is the pattern selector set on part of the buttonhole? set it to straight stitch or Zig Zag
SOURCE: Bostich N88rh fires like a machine gun
I Put a new trigger in and the safety on the head of the gun does not have to be pushed up in order to fire a nail in a board. I think when i pput it back together it was not done right. I do not have the instruction book.
SOURCE: spring control rod in kenmore model 253.55693400,
See if you can run the ice dispenser while the door is open. The auger may be turning but not the "drive blade" that delivers the ice.
