The front wheels link to the height adjustment controlled at the right rear wheel. The spring loaded link arm attaches to a pin on the height adjustment control. The link arm has come off the pin.
Tools: Long shaft bladed screwdriver and a pry bar.
Adjust the rear height adjustment so the second to last notch is engaged.
Position yourself with one knee on the front deck. This will allow you to control the height of the front and the back-n-forth movement of the link arm.
Position the pry bar with the short "L" section upwards, under the lawnmower. This will allow you to control the side-to-side position of the link arm.
Insert the screwdriver from the rear of the lawnmower. The rear wheel axle can be used for leverage This will allow you to control the up-and-down position of the control arm.
A little perseverance and you will be able to position the link arm back on the pin. It may be useful to remove the plastic cover of the lawnmower to allow a better view of the mechanism and link arm
