View and Download Durabrand CD2775SW operating instructions manual online. 5-cd ... Stereo System Durabrand 5 CD Changer Home Stereo System Operating ... PRECAUTION Follow the advice below for safe and appropriate operation.
Your car is 13 years old. The lens on your disc reader is also 13 years old . They get extremely dirty. Especially if the changer is in the trunk. I'd try using a disc lens cleaner to see if that fixes the issue. Could be that its just worn out. Hard to say . Have you taken it to a stereo shop ? I'd take it to one of those before you take it to the dealer. The dealer will waaaaaaay over charge you for diagnostics on a cd changer where as a local stereo shop would Probly fix it for ya for next to nothing.
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement... First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry. FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam and cause the player to display error codes E-01 thru E-07. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
It fixed it's self,the next day the changer was working normal.the battery is weak and going to be replaced.so maybe the problem was low system voltage." IT'S A JEEP THING " ???
NEED TO REMOVE POWER FROM UNIT THERE SHOULD BE A BLACK CABLE THAT GOES IN TO CHANGER REMOVE IT WAIT 5 SEC AND INSTALL BACK LIKE IT WAS AND THIS WILL CUT ALL POWER TO UNIT AND WILL 50% FIX THE PROBLEM LET ME KNOW
