I believe all you have to do is to connect the wires...( I understood ya already done that correctly )after that .select the AV frqv on the tv ....you would be more than sure prompt on the player to confirm or select the connection type .....they are usually preset-ed to recognize different conection and prompt you for an action ...
Well there shouldn't be much you can re-do, just unplug the component cables and re-plug. Make sure the device you are trying to watch is turned on and definitely outputting something across the component cables. Does the TV let you switch to component and nothing is on screen or you can't even switch?
Thanks
Tim
The first expert obviosly did not read or comprehend my comment. If the TV shows the two inputs that i named, of course it is on and is accepting inputs. And, as an experienced technician from WWII, I said that i checked the three Component cables. I wonder if he knows what jpeg is??.
