It is doing Fast forward and Rewind only. When Play button is pressed, Capstan engages but tape does not move. Capstan main motor also does not move. Is it threading problem or some thing wrong in motor or electronics?
Almost in this group of parts, problems with sear rubber belts, or rings and maybe brass corrosion inside a microswitch or little brass contact failed bad tension band or rings. a worn bus bearing of the capstan driving.
And if that is bad almost the long switch of recording/playing have also problems with corrosion after years . contactspray helps
