Question about Dictaphone 3740 Desktop Cassette Transcriber / Recorder
Dictaphone 3740 started to hum but would not play, FF or rewind. Have tried several tapes with same result. Turned machine on and off, unplugged it and still have same problem. Have tried it with the foot pedal and without, with headphones and without. It has been working fine until today. Now just beeps like at the end of a tape when I hit any button.
Posted by wsiim on
3vil3lvis
  • 43 Answers
If you press Play, Rew or FF and can hear something in the machine (even though the tape doesn't turn), then it's more than likely a broken capstan belt.
Posted on Jun 18, 2010
Sony tc k670
Take out the tape and press play, do the wheels move? if not the motor has burnt out, the tapes may have been sticky. Hold a tape and wind the wheels with your finger, are they difficult to move?
Dec 21, 2013 | Audio Players & Recorders
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
My EWC1394 records programs, but when I rewind th tape, it shuts off. This happens several times before it starts to rewind the tape.
this is caused by the tape winding too tightly so when it rewinds it gets tension and thinks it is at the end of tape ,so stops.
It pays to FF and REW several times on new or other peoples tapes to have the tape acclimatised to the tension on your machine. It may also need to be serviced if it is doing it to tapes you have previously FF to the end and rewound. Older tapes stretch a little more than new tapes so are more forgiving.
{Plese rate our help ++++Thanks for using FIXYA
Sep 26, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Jul 24, 2009 | Dictaphone 2740 Desktop Cassette...
What is the cue/f play/erase button on the top
When in RECORD, pressing the 'Cue' button will put a tone on the tape. This is used on the transcriber's machine to identify different jobs and such.
When in PLAY, pressing the 'F Play' button will change the playback speed to 1.5.
If you hold the 'ERASE' button and hold the portable in REWIND, it'll erase the tape while it's rewinding.
Hope this helps...
Jul 13, 2009 | Dictaphone Audio Players & Recorders
Tape won't play, FF, or eject.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
Jun 22, 2009 | Sony EVC100 Hi8 VCR
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Mar 05, 2009 | Dictaphone 2740 Desktop Cassette...
Camcorder has problems
I've had mine for about 3 years and just last year it started giving me playback problems....the screen would have blue stripes across it and sound won't play. I could usually fix it by rewinding and playing again...but it's not correcting itself right now... I hope I didn't waste 60000 yen on this c_c;
Oct 07, 2007 | Video Cameras
Dictaphone 3740 Desktop Cassette Transcriber / Recorder Logo
206 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
