When I press play, the display reads, PLAY for a couple of seconds, then HIFI for a couple of seconds, then _ _ : _ _ Same thing for FF and REW (no HIFI appearing) When I pop in a cassette it sounds normal, like it's about to play and then _ _ : _ _
SOURCE: Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
SOURCE: VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
SOURCE: zenith xbr616
I have the exact same issue, DVD don't play. The VCR works & the cds will play on DVD side, but it will not play DVD. Warranty is expired and we barely used it.
SOURCE: DVD will not finalize
I have a Zenith XBR413 that I have a problem with when I copy from VCR tapes to DVD-R discs. After I copy them, I can finalize the disc using the SETUP button on the remote and then choosing the very bottom disc icon at the bottom of the menu screen. It then leads you through the finalization procedure. But the disc will still not play on any DVD player but the XBR413
SOURCE: vcr/dvd burner combo
You will have to go into the dvd menu and finalize the disc for it to play on any other player. Check in your manual for more information.
