SOURCE: lost car keys, how to replace ignition/door locks
Can u open the doors using the ignigtion key or is it two seperate keys?
SOURCE: ignition key won t turn. steering wheel locked
the key may be worn badly or the ignition needs to be replaced.
SOURCE: 2005 Ford Escape won't start but hear a
This sound is the relay, Is the battery new if more than 1 and 1/2 yrs. you need to replace your battery.
Is your engine cranking when start, if not, the battery need to be replace.
SOURCE: key in ignition won,t turn 2004 ford escape
several things, does key go in and out easily, turn steering wheel in both directions while turning key. sometimes the steering wheel lock binds the lock cylinder and turning wheel releases the pressure and it will turn. other than that the ignition cylinder is jammed, wet key lightly with lubricant such as wd-40 and a light bit in key hole and try key again, If key is heavily worn out , try a different ignition key as it might not be disengaging all the tumblers in lock, if all this fails you need a new cylinder.
