Epson Stylus R290 InkJet Printer Logo
b
ben amedoyror Posted on Jun 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What makes power side and print head for Epson stylus r290 not working
The print head only moves and stop half way
Electro Med Services
Level 3:
  • Epson Master 6,694 Answers
  • Posted on Jun 07, 2016
Epson Master
Level 3:
Answers
6694
Questions
Helped
1872648
Points
21433
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
How do I access the fuse on an Epson R290?
Open the case. Check with Board. There might be a fuse near the power inlet lead.
Epson r290 double red light blanking error how i can resolve ?
Link to you Manual.
The answer according to your manual, under "Diagnosing the Problem" is either :
The Printer Cover is open;
The Front Tray is not in the correct position;
The print head is obstructed by jammed paper or other foreign material and cannot return to the home position.
Tallon41
I got same problem, but the epson man tell me to change head which course 150$. too expensive,
Print heads are expensive. It is not much more expensive to buy a new printer, it will be a later model and better printer.
My r290 add red color to my photos
*** I'll be more than happy to help you on that. you might be talking about R280, because theres no R290 for epson. there is a great possibility thatsome of the nozzles of your printer are clogged by dried inks, thats why when it prints, the inks are not equally distributed or is not balanced.to check that, print a nozzle check, and if you see gaps or breaks, between the lines, do head cleaning. this is how you can do it, its very easy for you. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, that the CD/DVD tray is not inserted in the printer, and the red maint.5.1.8.jpg ink light is not on. (If the red maint.5.1.9.jpg ink light is on, you need to replace a cartridge.) 2. Turn the printer off and make sure the front tray is in the paper (lower) position. 3. Make sure letter-size plain paper is loaded in the printer. 4. Hold down the maint.5.1.10.jpg paper button, then press the maint.5.1.11.jpg power button. Hold down both buttons until the maint.5.1.12.jpg power light begins to flash, then release the maint.5.1.13.jpg power button. maint.5.1.14.jpg 5. When the nozzle check starts to print release the maint.5.1.15.jpg paper button. Check the nozzle check pattern that prints to see if there are gaps in the lines. maint.5.1.16.jpg 6. If there are no gaps or lines, the print head does not need to be cleaned. If there are gaps or lines, or the test patterns are faint, follow the steps in do the Head Cleaning to clean the nozzles. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, and the red maint.5.1.23.jpg ink light is off. (If the red maint.5.1.24.jpg ink light is flashing or on, you need to replace a cartridge.) 2. Hold down the maint.5.1.25.jpg ink button on the printer for approximately 3 seconds. The printer runs a head cleaning cycle and the green maint.5.1.26.jpg power light flashes. Cleaning takes several seconds. Caution:
Never turn off the printer while head cleaning is in progress. You may damage it.
Do not insert the CD/DVD tray until cleaning has finished. 3. When the green maint.5.1.27.jpg power light stops flashing, make sure paper is loaded in the printer, then print a nozzle check to determine whether you need to clean the print head again. Print Head Nozzles If you don’t see any improvement after cleaning three times, turn the printer off and wait overnight. This allows any dried ink to soften. Then, try cleaning the print head again.
Problem with cleaning heads on Epson Stylus R290
Hi, enter the set up, scroll down to maintenance, click on the maintenance, different options will pop up, click on cleaning the cartridge head and make sure you also align the cartridge after cleaning the head, the alignment is under the maintenance option.
I wish you best of luck.
5helpful
2answers
Epson r290 no power after i turn off because 2 red light appears
while printing the two red lights turn on and stop printing,i press the power to off.. i turn it on so many times but still no power.. in the morning, i press the power to on and the 2 red lights appears again, then i turn it off, ..i try to turn it on many times but still no power. help me pls...
2answers
Epson r290 printer no printing now
try to clean yellow nozzle manualy, use a spuit and flexible pipa (as in cleaning mechanism), use a cleaner.
Epson r270 power turned off..
chk virus in computer than r290 not working in virus your computer ma bee virus plz reinstall window than print its will bee ok
any problem email me [email protected]
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
