I just bought a used Sony KDL-52S5100. I installed it 2 days ago. Has worked fine for 2 days and was fine this morning but turned it on this evening and has the solarized picture. I went to the menu and the menu is not solarized. I went to the guide (on Dish Network) and it also looks fine and is not solarized. Please Help.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
I have a Sony model KDL-32BXR6 that the TV Guide first
showed no listings this past weekend.
Last night when I entered the Guide the screen displaying the
Setup/Display Setup Progress came up stating "In Progress". Same thing this morning. Something must have changes with the input signal
if this occurred with two different sets.
